Hi everyone,
I am planning to use the cadence/publish interval property within a mesh network. I can not find any examples on how to use it. I know I can set it in the nrf...
Hello Nordic!
We are currently in the process of incorporating the NRF9160 as the core 4G/GNSS module for our vehicle tracking system. However, based on our experience,...
I am developing nrf52832 with nRF5 SDK v17.1.0 and SoftDevice flash_s132_nrf52_7.2.0_softdevice.
The FW uses FreeRTOS. In standby mode of the program, it consume about 37...
Dear Support Team
For the nRF52805, If we use D5 and D6 as the GPIO and use internal 32.768khz, do this affect the stability of the BLE connection? Many thanks.
Dear:
Customer: SMART TECHNOLOGIES, analysis of excessive nRF52832-QFAA current in products.
Abnormal product is PG door lock. Product specification requirements 75uA...
Hi! I am using cellular GNSS example 6 provided by DEV Academy. I am getting compile time duplicate IRQ error message.
This is output of IRQ ERROR message.
Following...
I have a BLE peripheral project that is based on NCS 2.5.0 using the typical flags for firmware update:
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP...
Hi, I'm currently trying to enable softAP mode and have an HTTP server set up at the same time with the nRF7002DK.
The programs/samples I'm using for each are: HTTP server...
I have a lis3dh sensor where I want to configure the interrupts. I am currently struggling to extract the information from the irq-gpios phandle to the c driver. I went through...
we are facing an issue of loading the application written with nRF Connect SDK to the nRF52840 which has nRF5 SDK's secure bootloader. Update process should be performed...
Hi everyone,
Hi all,
I'm a beginner of Nordic system, I use nRF52832(PCA10040) to develop my project, here is my properties:
Board: nRF52832 nRF5 SDK Version: 17.1.0 Soft device: S212...
Hi
I'm using nrf toolchain/sdk 2.5.2.
Got a strange problem with my QSPI NOR flash interface. when i run flash_erase i get error message "qspi_nor: Failed to schedule...
Hello Nordic!
Dear Nordic Support
Recently I have the issue that the nrf-connect.toolchain.path, set in the VS-Code workspace file, doesn't correctly resolve if predefined VS-Code variables...
Hi, I am using nrf52840dk along with Quectel BG95 module with the sample "cellular modem"
Can i able to use the bg95 driver for nrf52840??
When i tried to build it for...
hi,
I want to know how Bluetooth allocates channel resources as a master.
Assuming a Bluetooth master is connected to 8 slaves simultaneously, how does the master allocate...
We have a project based on nrf5340 audio demo,Now we upgrade SDK from NCS2.4 to NCS2.6.
But when I built the DFU, I found that FLASH was not enough
I know this problem...
Hi guys!
Right now I have my custom board which used nRF52833 SoC. There is only one reset button on custom board and dfu performed via uart.
I flashed four hex file ...
Hi supporter
SDK version:v2.5.2 IDE: VSCODE computer platform:window10 64 bits
I try to connect nRF5340-DK or nRF7002-DK to extenal board(nRF7002 and nRF5340 combo modules...
Is there any strategy/method or example of how to perform (non Nordic) MCU to (non Nordic) MCU firmware update via UART ? We want the non Nordic chip to do the firmware...
Unable to use uart ,I2c,SPI together as shown in the error message. I am attaching the dts overlay file
Is there any way to use all UART,SPI,I2C together. Please let me...
