Hello
I am trying to connect the nRF9160 -DK board to nRFCloud using CoAP protocol. I have written an application for this case. I tested my application with two different...
We have used hundreds of thousands of Nordics over the last few years and have never actually had any larger problems with programming.
In the last production batch, 200...
Hello Nordic!
We are currently in the process of incorporating the NRF9160 as the core 4G/GNSS module for our vehicle tracking system. However, based on our experience,...
I am developing nrf52832 with nRF5 SDK v17.1.0 and SoftDevice flash_s132_nrf52_7.2.0_softdevice.
The FW uses FreeRTOS. In standby mode of the program, it consume about 37...
Hi! I am using cellular GNSS example 6 provided by DEV Academy. I am getting compile time duplicate IRQ error message.
This is output of IRQ ERROR message.
Following...
I have a BLE peripheral project that is based on NCS 2.5.0 using the typical flags for firmware update:
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP...
I have two products which are very similar. They differ in which pins are mapped to which functions. Let's call the Product A and Product B.
I made a mistake and left two...
I initially tried communicating between the nRF52840-DK and an Adafruit CP2102N - USB to Serial Converter to ensure the peripheral_uart example code on the nRF Connect SDK...
I am currently researching the capabilities of Bluetooth Mesh with the nRF5340 DK. I have two DK's which are communicating over Mesh where one sends data (20 bytes) to the...
Hi Nordic,
In my project, I have a NRF9160 and a NRF52832 with a ble host/controller stack over SPI HCI on NCS v2.5.2 As soon as I activate the HCI SPI in my project, the...
NB: I'm not using the full SDK, only the devicetree extension. therefore I must provide the path to zephyr base.
app.code-workspace
This works:
Unfortunately, this is...
Hi supporter
SDK version:v2.5.2 IDE: VSCODE computer platform:window10 64 bits
I try to connect nRF5340-DK or nRF7002-DK to extenal board(nRF7002 and nRF5340 combo modules...
Hello Team,
I have soldered an MFF2 SIM at U6 location of the NRF9161 DK PCA 10153 ver 0.9.1. I do not insert the plastic sim in J5 position. I am unable to make the MFF2...
Dear support team, The j-link firmware of my nRF52840-DK v3.0.1 is no longer available. Please provide the firmware of nRF5340 so that I can repair the DK.
BR,
zero
Can a high reflection coefficient (say -1dB instead of wanted <-6dB) damage the LTE transceiver or does it have internal protection?
Is it possible to disable the unwanted...
On a new board based on nRF9160 I am having trouble figuring out how to bring up the board.
I am using Azure IoT hub and can successfully build an application that can connect...
Hi Team,
Can you please tell the AT commands of below.
1. AT command to keep nRF9160 in sleep mode.
2. AT command to wakeup nRF9160.
Sravan Rikka
Hi all,
NRF5340 NRF Connect 2.6.0
We would like to perform the following operations on the NRF5340: * Read FICR.DEVICEADDR (BLE random MAC is also fine). * Set the BLE...
Hi Team,
Can you please provide your inputs here.
1. Is the nRF9160 SLM supports NIDD(non-ip data delivery)? If yes, can you please provide the AT commands to configure...
I am attempting to work thru the tutorial exactly per the instructions, and I'm stuck in Lesson 1 at
6. Wait for the device to connect to nRF Cloud.
The Cellular Monitor...
I have investigated Zephyr's power managemen API and have the a few questions regarding the nRF52840-DK. The nRF52840-DK was powered externally by the N6705B DC power...
Hello!
I'm trying to change the output TX power in the nrf5340 audio dk. I'm setting:
CONFIG_BLE_CONN_TX_POWER_NEG_40DBM=y
CONFIG_BLE_ADV_TX_POWER_NEG_40DBM=y
