We have used hundreds of thousands of Nordics over the last few years and have never actually had any larger problems with programming.
In the last production batch, 200...
Hello Nordic!
We are currently in the process of incorporating the NRF9160 as the core 4G/GNSS module for our vehicle tracking system. However, based on our experience,...
I am developing nrf52832 with nRF5 SDK v17.1.0 and SoftDevice flash_s132_nrf52_7.2.0_softdevice.
The FW uses FreeRTOS. In standby mode of the program, it consume about 37...
Dear Support Team
For the nRF52805, If we use D5 and D6 as the GPIO and use internal 32.768khz, do this affect the stability of the BLE connection? Many thanks.
Hi! I am using cellular GNSS example 6 provided by DEV Academy. I am getting compile time duplicate IRQ error message.
This is output of IRQ ERROR message.
Following...
I have a BLE peripheral project that is based on NCS 2.5.0 using the typical flags for firmware update:
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP...
I initially tried communicating between the nRF52840-DK and an Adafruit CP2102N - USB to Serial Converter to ensure the peripheral_uart example code on the nRF Connect SDK...
Hello, Karl Ylvisaker. When I use 52840 scan, I sometimes fail to scan other Bluetooth devices for a long time, but the scan will resume after a long time. Other Bluetooth...
Hi all,
NRF5340 NRF Connect 2.6.0
We would like to perform the following operations on the NRF5340: * Read FICR.DEVICEADDR (BLE random MAC is also fine). * Set the BLE...
Im using nRF Connect for VSCode on a Mac, creating a new application from any of the Matter samples works great with SDK 2.5.2.
However when using SDK 2.6.0 again creating...
For reasons beyond my control I need to do some changes to a nrf9160 project that was developed using nrfConnect v1.2.1. I know the ideal situation is to upgrade it to the...
Hello!
I'm trying to change the output TX power in the nrf5340 audio dk. I'm setting:
CONFIG_BLE_CONN_TX_POWER_NEG_40DBM=y
CONFIG_BLE_ADV_TX_POWER_NEG_40DBM=y
Hi, I'm currently trying to enable softAP mode and have an HTTP server set up at the same time with the nRF7002DK.
The programs/samples I'm using for each are: HTTP server...
Hi everyone,
I am planning to use the cadence/publish interval property within a mesh network. I can not find any examples on how to use it. I know I can set it in the nrf...
hi
I am developing using nRF52832 and SDK 17.0.1 (NUS).
I configured paring using BLE Name filter...
I can't find the part that modifies the central response...
Hi there,
I'm using an nRF52840 pin to monitor GPIO state transitions, but it keeps reporting frequent phantom low transitions without high transitions in between. According...
I have a lis3dh sensor where I want to configure the interrupts. I am currently struggling to extract the information from the irq-gpios phandle to the c driver. I went through...
we are facing an issue of loading the application written with nRF Connect SDK to the nRF52840 which has nRF5 SDK's secure bootloader. Update process should be performed...
Hi all,
I'm a beginner of Nordic system, I use nRF52832(PCA10040) to develop my project, here is my properties:
Board: nRF52832 nRF5 SDK Version: 17.1.0 Soft device: S212...
Hi
I'm using nrf toolchain/sdk 2.5.2.
Got a strange problem with my QSPI NOR flash interface. when i run flash_erase i get error message "qspi_nor: Failed to schedule...
Hello Nordic!
